Spot The Dot
norwichmike
Spot The Dot
Post by norwichmike » Wed Nov 04, 2015 9:52 am
Morning all from a wet Norfolk.
Took a few high level shots last weekend at 2400mm so thought I would post up a couple up....
TC-JOL A330 THY
ImageTC-JOL by Mike Burdett, on Flickr
PH-CKB B747 KLM Cargo
ImagePH-CKB by Mike Burdett, on Flickr
D-ALPI A330 Air Berlin
ImageD-ALPI by Mike Burdett, on Flickr
And a sneaky one :ninja:
05-5144 C17 USAF
Image05-5144 by Mike Burdett, on Flickr
Still need to get more practice in to make these better.
MB
Mike B
pig hunter
Re: Spot The Dot
Post by pig hunter » Sat Nov 07, 2015 4:59 pm
how do you achieve 2,400 mm please?/
camera??
thanks
ph
norwichmike
Re: Spot The Dot
Post by norwichmike » Sat Nov 07, 2015 9:27 pm
pig hunter wrote:how do you achieve 2,400 mm please?/
camera??
thanks
ph
Hi Pig Hunter.
Well lets start with the easy bit shall we..........
Camera is a Canon EOS
Now to achieve the 2400mm I have a Sky-Watcher Telescope which when I connect my camera to it equals 1200mm. Which allow shots like this....
ImageA7-AED by Mike Burdett, on Flickr
I then decided to purchase a 2x Barlow to make the telescope 2400mm and allow shots like this...
It is all manual focus and with the air conditions you will end up deleting many images and saving a few.
Hope that helps a bit?
Mike B
Mike B
Paul Zietsman
POTY & SPOTM winner
Re: Spot The Dot
Post by Paul Zietsman » Sun Nov 08, 2015 2:32 pm
Mike, I am amazed at just how sharp the images are. How do you keep the telescope steady as I assume it does not sit on a tripod. I find the concept of photographing aircraft at altitude fascinating.
youth
Re: Spot The Dot
Post by youth » Sun Nov 08, 2015 6:24 pm
'SPOT ON' ; )
norwichmike
Re: Spot The Dot
Post by norwichmike » Mon Nov 09, 2015 9:37 am
Paul Zietsman wrote:Mike, I am amazed at just how sharp the images are. How do you keep the telescope steady as I assume it does not sit on a tripod. I find the concept of photographing aircraft at altitude fascinating.
Paul,
The scope is in a stand on the ground
Once you connect the camera it's hard to find the aircraft and the manual focus makes getting a sharp image difficult. I have only used this a few times and the panning and keeping the aircraft centered in the screen is hard work and will take lots of practice to get better.
I enjoy taking the photo's of the overflights it brings a different side to the hobby.
Mike B
Mike B
Re: Spot The Dot
Post by PorkScratching » Mon Nov 09, 2015 9:59 am
I have a smaller version of that telescope for astronomy. It's difficult enough keeping stars, planets etc. in the frame as they move across the sky, so I can imagine how difficult it is to track an aircraft, plus keep it in focus and take the shots!
pig hunter
Re: Spot The Dot
Post by pig hunter » Mon Nov 09, 2015 5:13 pm
Thank you
that is pretty amazing
very clear shots for such an arrangements....
well done
ph
Re: Spot The Dot
Post by Wallie » Mon Nov 09, 2015 7:09 pm
Don't often see such pics. Nice !!
Paul Zietsman
POTY & SPOTM winner
Re: Spot The Dot
Post by Paul Zietsman » Mon Nov 09, 2015 8:03 pm
Mike,
Thanks for the answer. It makes your images even more remarkable, you must have patience to have developed the skill.
norwichmike
Re: Spot The Dot
Post by norwichmike » Tue Nov 10, 2015 9:43 am
Thanks all for the comments. Hope to share some more soon.
I have only used the 2x connection this once and It was all test work but happy they came out half decent. Hoping the weather gets better soon so I can practice some more.
Mike B
Mike B
Users browsing this forum: Bing [Bot], Google [Bot] and 138 guests
