NEW FMS Mini PA-18 Super Cub
Discuss anything related to civilian aircraft modelling here.
dominicm
Post by dominicm » Tue Jul 15, 2025 3:53 pm
First flights of FMS new mini PA-18. It has reasonable detail for little scale model and the well applies stickers do make it highly visible. The red stickers were pre-applied but there was a blue set in the box! We enjoyed flying it especially it's ease of take off/landing. The large wheels allow smooth take-off and it almost perfect landings can be achieved. Even in a 10-15mph breeze it is very stable in the air. We also liked that the non-stabilised/Manual mode which IS very flyable unlike many other mini Warbirds you can buy. We think the 'return to home' feature is a little mis-named. Preset the direction at take-off and it will always head back on the opposite to that direction when the RTH button is used. The red Stunt button works perfectly every time. Execute loops and rolls with ease. If travelling at 2/3 throttle or more then the rolls are very axial. The propeller does detach VERY easily from the claw mount on the motor shaft. The smallest touch on the ground and it will ping off so be careful you don't lose it. I wish they had included at least 1 spare propeller and prop hub as they are the components that are most likely to get broken.
https://www.youtube.com/watch?v=U2eHexlynUY
Return to “Modelling”
