Has anybody had problems with the new photobucket site?
I've tried to use it for the first time this evening and it just seems to have locked up on me , even re-booting hasn't cleared it. I can't see where to log out and the 'help' button and switch to old site option dont seem to work either. any advice please?
new photobucket site - generating multiple image codes
Re: new photobucket site
I switched back to the old site a few days ago and it's been working great, seems like loads of people are having the same problem as yourself though - hopefully it'll sort itself out shortly for you.
thanks Mike, can't unlock it at present and can't log off
Re: new photobucket site - generating multiple image codes
the old site is now a thing of the past and I'm stumped
I've spent ages trying to generate the image codes for the photos I uploaded (that was easy-ish apart from them trying to hide in the library a couple of times) , on the old site you (or I) could select all the images in a folder then generate the image codes all at ones - far quicker, there must be a way but I can't work it out, has anybody else worked out a way please?
Nope, I don't have a clue - anyone know ????andygolfer wrote:the old site is now a thing of the past and I'm stumped
Thanks Mike, I have since been told this by a friend on another forum , I'm sure he won't mind me sharing it:
To select several links in Photobucket - click on 'Organize' - select pictures you want links for (i.e usual way ctrl click each one or shift to select several) then click on Link Codes at bottom of page - you may have to click on double up arrows to reveal the 'slide up' panel. A window should then appear with various link formats. Click on IMG codes and then paste them into your post. Job Done.
hope that's of use to anyone else struggling with the new site
