Hi. In august i went to compton abbas airfield and a jet ranger took off as i got there. The reg was N-Z06HE. I can not find any info on it. If it was a g reg i could find out about it on the uk register but don't know where to look for N reg. I have found one site in the usa but it kept saying invald reg Hope someone can help
Thanks in advance
Stan
Jet Ranger INFO
- Phil Standfield
- SPOTM winner
Re: Jet Ranger INFO
Hi Stan,
N206HE is a Jet Ranger, maybe you mis-noted the registration?
I saw her at Helitech last year.
Reggie
Reggie
Re: Jet Ranger INFO
Hi
American registrations can be found at http://registry.faa.gov/aircraftinquiry/" onclick="window.open(this.href);return false;.
If there is a letter after the N ignore it. ( Older U.S. registrations often had a C after the N, but that is now 'not done', unless the FAA give you a special dispensation to apply the letter after the N ,i.e. usually only for historic aircraft).
So your NZ is N (probably 7, possibly 2) 06HE, but 7 comes up as non existant , leaving us with 2, a Jetranger .
An alternative method is look up what you think it is here http://laasdata.com/fra/index.php" onclick="window.open(this.href);return false; , this shows N206HE as a Jetranger based in Weymouth.
So my guess would be N206HE , but that is just a guess.
h.t.h.
Terry
h.t.h.
Terry
I got a little black book with me poems in
- Phil Standfield
Re: Jet Ranger INFO
Hi. Thanks to you both. I thought someone may be able to point me in the direction of where to find out. I have now book marked the sites for future. Yes i did misread the reg and i was looking at a picture as well.
Thanks again
Stan
Thanks again
Stan
Re: Jet Ranger INFO
Stan,
Jet Ranger III N206HE is Dorset based (Chickerell) so is probably the example you saw at Compton Abbas. Hope this helps.
- Phil Standfield
Re: Jet Ranger INFO
Hi. I have put a couple of pictures up in the helicopter section.
Stan
Stan
Re: Jet Ranger INFO
Looking at those pics through the bottom of a glass were we ?
I see 'the' advent calendar has the 1st opened.
Users browsing this forum: No registered users and 11 guests
