SPOTM February 2017, Taildraggers - voting poll
This is the voting poll for the February 2017 Special Photo Of The Month competition, the subject was ‘Taildraggers”, any civilian registered aircraft with a tailwheel or tailskid
Thank you to everybody who submitted entries - we had 23 entries of a very high standard.
The poll is open to all registered members but you must be signed in to vote.
Please submit your THREE votes using the poll provided.
- You cannot change your vote once submitted and please vote for all 3 choices before hitting the submit button as you cannot go back to place 2nd and 3rd choices later
- Each of your three votes holds equal value
- The poll will run for 7 days from the time of creation
- Please don't vote for yourself! There is no way to enforce this, just an honesty policy
- Entrants are listed in alphabetical order for ease (with a short description to help identify the entries)
- Results will be announced on the photo thread in the usual manner and the winning photos will be posted in the Hall of Fame
the entries can be viewed here:
http://www.civilianaviation.co.uk/forum ... 10&t=27307
thank you for your support
Andrew
Andrew
- BringBackEGDG
Re: SPOTM February 2017, Taildraggers - voting poll
Just went to cast my vote at 11:30am to find the poll already closed. My vote would have given a clear cut winner providing that nobody else missed out on the voting.
BringBackEGDG
BringBackEGDG
- Nighthawke
It does state 7 days from the time of creation - 11:14 on the 2nd. That may possibly be a feature of the forum or Andy is on the ball this morning!
- BringBackEGDG
Why is it shown on my computer that the Poll ended at Thu Mar 09, 2017 12:14 pm
BringBackEGDG
BringBackEGDG
Because, like me, you must still have the forum clock set to BST and haven't adjusted it for winter (bit late now though as the clocks will be changing again soon!)
Mark
Mark
- BringBackEGDG
Thanks Mark sorted now, Best leave it on winter time that way I should always be early!!bizfreeq wrote:Because, like me, you must still have the forum clock set to BST and haven't adjusted it for winter (bit late now though as the clocks will be changing again soon!)
Steve
I've been on the ball at Stansted and Lakenheath today!Nighthawke wrote:It does state 7 days from the time of creation - 11:14 on the 2nd. That may possibly be a feature of the forum or Andy is on the ball this morning!
Bringback EGDG:The rule changed 2 months ago after we (the moderating team) monitored the voting pattern and we found that nearly all the votes are cast in the first 3 days then there's a lull and usually one or two on the last day, the rule change was notified here back in mid January: http://www.civilianaviation.co.uk/forum ... 10&t=23950
sorry you missed out on voting but it would be unfair to change it now and deprive two people a win albeit a joint one and in any case i don't think we could set a precedent by re-opening a poll otherwise we could get future requests to do the same again, I did highlight the rule change by putting '7 Days' in red as well.
well yes, the poll has closed and we have 3 joint winners this month including one first time winner
so it's special congratulations to Col with his Pitts in a cloud of white smoke
and then to our more seasoned winners, Bizfreeq also with a Pitts at Oaksey Park
and Paultojo with his P.40 at Duxford
I have posted them in the Hall of fame here: http://www.civilianaviation.co.uk/forum ... 12&t=27515
thank you to everybody who entered (a great 23 entries) and / or voted
- BringBackEGDG
Hi Andy
I am fully aware of the changes to the voting poll and certainly do not have a problem with them.
My problem was that on my computer it showed the time for the poll to end being at 12.14pm, This being my fault in not changing the setting in control panel to winter time from BST. I will in future keep it on winter time all year round so this does not happen again.
Steve
Steve
thanks Steve, thought you hadn't noticed the rule change.BringBackEGDG wrote:Hi Andy
Steve
We (usually Mike) normally post a reminder re the forum time when the clocks change, Also you might notice if you're not in synch with the time on the forum (or vice versa) things like the poll end time will be different if you are not logged in to when you are.
It is very easy to change TBH so I would recommend doing so. How to do it (for ANYBODY who doesn't know):
1: open 'User control panel' on home page of forum - top left just under'board index'
2: select Board preferences from the tabs
3: in 'edit global settings' last option but one is 'Summer Time/DST is in effect:' in this just select Yes or No depending on whether BST is in effect, at present it should have'No' selected.
when we do the spring reminded I will ensure this is repeated there for those that don't notice it here as it's a bit off topic for this really.
Users browsing this forum: No registered users and 49 guests
