I am trying to upload my first set of pictures but after I copy the Photobucket IMG link (as detailed in the instructions) into a new topic rectangle, I do not see the image when I select the Preview button. The image size is less than 1200x1200 and when I paste just the link and select it, I am able to see the picture. Any ideas on what I am doing wrong? The Photobucket upload setting is set at: Best possible quality (while staying 1mb or less). I tried some of the other suggestions from this forum page and again no luck.
Thanks,
Dirk
Uploading Pictures from Photobucket
Re: Uploading Pictures from Photobucket
You seemed to have cracked it Dirk, dead easy - isn't it ? :- http://www.civilianaviation.co.uk/forum ... 032#p41032" onclick="window.open(this.href);return false;
Mike,
Once I figured out that it was an issue with IE 9, the uploads and preview worked fine.
Dirk
Dirk
