Shoreham - Spotter Friendly?
EGVP
Post by EGVP » Fri Mar 05, 2010 9:49 pm
Hi all,
Just wondering if Shoreham is spotter friendly, might be visiting at some point next month if the weather's nice!
Re: Shoreham - Spotter Friendly?
Post by Martin » Sat Mar 06, 2010 12:52 am
chris.globe wrote:Hi all,
Yes, great views across the apron from the cafe (also allows good photo's of aircraft parked on the main ramp). Views can be obtained aswell from the road that runs along the Eastern side of the airfield, between the airfield & the river. They also do hangar/ramp tours
http://www.shorehamairport.co.uk/visitorcentre.asp" onclick="window.open(this.href);return false;
The based bizprops (Pc12 G-INTO, Be350 M-FLYI and Be90 N106ML) are usually hangared with MCA unless they're due out/recently arrived. MCA also do maintenance on King Air's so there may be a couple of visiting King Air's around. so the tour is worth while if you need these. TBM700 N324JS is also pretty regular (along with a few Pc12's & a couple of Ce510's) and these usually park on the main apron in front of the Cafe when visiting.
EGVP
Post by EGVP » Sat Mar 06, 2010 2:35 pm
Cheers Martin, looks like a hangar tour is in order! :)
Return to “Shoreham”
