Fastjet A319 Z-FJE
- Wiltshire_Victor
Fastjet A319 Z-FJE
A friend who lives a long way from Kemble wants to see this frame but is reluctant to make such a long trip if it's no longer visible or has met its maker. Can anyone confirm please, or otherwise whether it is still visible? Many thanks
Find me and 360 other enthusiasts at http://aviationforall.proboards.com
Find our Aircraft Con Trail page at https://www.facebook.com/groups/1552422878165906/
Re: Fastjet A319 Z-FJE
On 23/11/2017 it was missing vertical tail plane, engines and undercarriage.
Received this yesterday from Severnside Aviation;
Took a trip to Kemble to see the new arrivals, as usual there were bits and
pieces which could not be positively identified.
2-KKSF ATR Belfast apron Fuselage only
F-GLZH A340 Scrap Compound
G-CELA B 737 Belfast apron Less Engines
G-CELI B 737 ASI Hangar Less tail
G-CELW B 737 Belfast apron Less Engines
G-CELZ B 737 Belfast apron Less Engines & tail
G-CJKC BAe 146 Belfast Apron Fuselage only
G-DAJB B 757 Scrap Compound Fuselage only
G-MKGA B 747 Twy C Intact
G-ZAPO BAe 146 Scrap Compound Nose Only
G-ZBAU A 320 ASI Apron Intact
HL8232 B 737 ASI Apron Less engines
HS-TJF B 777 Scrap Compound Less Engines
M-FTOH B 727 ASI Apron Intact
PK-KSC ATR ASI Apron Intact
TF-AAE B 747 Belfast Apron Less Engines
TF-AMV B 747 North Apron Less Engines
TU-TSN A 319 Partially in ASI Hangar Intact
Also noted on the Belfast Apron was the fuselage and wings of an EMB less
the nose, possibly one of the Finnair ones. In my last report I said that
DAJB was in two halves this was wrong, it has had a section cut out of the
fuselage and when viewed from certain angles appears to be in two pieces.
Two visitors of note
G-FPEH Helicopteres Guimbal Cabri G2
G-RJVH Helicopteres Guimbal Cabri G2
Looks as if Z-FJE may have been chopped.
Sorry for the bad news.
