Local Aircraft you are most likely to see at EGBJ
cory33
Location: Gloucestershire Airport EGBJ / London Oxford Airport EGTK
Post by cory33 » Mon Aug 31, 2015 10:24 am
Hello and welcome, This is a short guide to local aircraft that operate in and out of Gloucester throughout the week and you are most likely to see one. :D
Executive Aviation operate 3 Citation Bravos *hangar AND AIRCRAFT CAN CLEARLY BE SEEN BY MULTIPLE GATES AT ALL TIMES UNLESS hangar IS CLOSED*
G-PJDS
G-YPRS
G-CGEI - These operate a lot in and out of Gloucester throughout the week, so you will most probably see one of these.
The Little Jet company Operate One Citation Bravo and On king Air 350 *hangar/AIRCRAFT CANNOT BE SEEN*
G-IPLY - Citation Bravo
G-BZNE - King Air 350 - These two operate a lot in the week, The citation tends to go out quite early in the morning around 6-9AM
You can check there twitter here (https://twitter.com/littlejetco?lang=en-gb) and they often post empty legs so you can see what day and time one will be coming in or out.
Flight Partner - Aircraft are normally put on stand 1 :D *AIRCRAFT KEPT IN hangar 1 AND WHEN THEY ARE PULLED OUT YOU CAN CLEARLY SEE THEM EITHER ON STAND 1 AND WESTERN APRON*
Flight partner operate a few jets at Gloucester
G-SDRY - Citation CJ4 (Goes in and out a lot in the week and weekends)
N22UB - Citation CJ4 ( Goes in and out a lot in the week and weekends)
N95FP Citation CJ4 ( Hardly ever at Gloucester mostly always away but from time to time does drop in for a visit)
M-WMWM Citation CJ2 ( Semi Based at Gloucester, can be seen flying in and out quite alot)
They operate many other jets but they hardy every come into Gloucester so i don't think it i worth saying about them.
Direct Aviation (Big Massive Glass hangar) *ALL AIRCRAFT CAN BE CLEARLY SEEN AT ALL TIMES*
Direct Operate at the current moment two Challenger's a 601 (GLWDC) and 604 (MLOOK)
*VERY CAREFUL AT TAKING PHOTOS AROUND THE hangar THEY DO NOT LIKE IT*
G-LWDC (601) Does not do much these day but does fly from time to time and is for sale some times they bring her out of the hangar, If she does fly it is normally early 0730
M-LOOK (604) Does more flying and often goes out early, normally 0730, and then often arrives bad at around 1800-2000
They also hangar MWOOD - Citation 550 Bravo and N525DT CJ2
MWOOD - Citation 550 Bravo is mostly away but has lately been at Gloucester quite alot and is Kept in DA hangar
N525DT - Citation CJ2 Fly's in and out not alot but often, she is also kept in DA hangar.
M-GCAP - Piaggio P.180 Avanti Can fly alot often also departing in the morning arriving at night, But she is kept in Staverton Flying school hangar so she cannot been seen if she is getting ready to come in but she can be tracked on Flight radar 24 as MGCAP.
Re: Local Aircraft you are most likely to see at EGBJ
Post by Martin » Thu Jan 10, 2019 7:27 pm
A newish bizjet resident at Staverton is Fa7X M-GGBL
Return to “Gloucester Staverton”
Users browsing this forum: No registered users and 6 guests
